03-22-2016 02:44 PM - edited 01-04-2022 12:51 PM
I was reading "Incessant texts from 611" thread started by @bradp36 and was confused by the content of the error text he was getting from PM, namely "Sorry, we do not offer text messaging outside of Canada at this time"...
If I go to the Plans page, it shows International Texting as an option, but the Unlimited Text superscript 3 fine print says "...messaging to and from non-Canadian numbers, are not included"...
Looking back through the Community a bit, it looks like international texting was initially not offered on the new plans, but came back in late last summer. If that is the case, both those items above appear to be leftovers from when it was off and should really fixed to avoid confusion. (And if they are right, then just what does the international texting option on the plans page mean?)
08-09-2018 04:21 PM - edited 08-09-2018 04:21 PM
@NB wrote:Hi, I have the PM international unlimited texting option and am inside Canada. But my sent international texts are not received and I do not receive international text sent to me. My international texts worked normally when I was with Bell. PM texting works normally with Canadian numbers. Any ideas?
I've always found international text messaging to be a crap-shoot, no matter which carrier I'm using. Sometimes it works but sometimes it doesn't, I would say of an unscientific success rate of only about 50% (maybe not that bad but noctoriously unreliable). The difficulties likelly lie with getting the 2 carriers involved to co-operate with each other.
08-09-2018 03:53 PM
05-01-2017 03:34 AM
@zeester wrote:Hello!
Sorry to revive an old thread, I just needed to confirm: if I have International Text on my plan, that means that I'm able to receive texts coming from outside Canada, right?
Thanks!!
You can receive a text message sent from anywhere but only while you are in Canada connected to the Telus network.
05-01-2017 01:52 AM
Hello!
Thanks!!
09-21-2016 07:29 AM
09-21-2016 07:13 AM - edited 09-21-2016 07:14 AM
Hi @themotors, welcome to Public Mobile! Unfortunately, as @stonechucker has said, PM currently has no service available outside of Canada, so you must be physically in Canada to use your PM service, regardless of plan or add-on choice.
09-20-2016 09:03 PM
Public Mobile works only inside Canada. The is not an option available to roam, whether it be voice, txt, or data. Therefore, no service outside of Canada.
you can send voice, and txt messages internationally if you have it available via base plan and/or ADDONS, but you must be inside Canada to do so.
stonechucker
09-20-2016 08:41 PM
09-19-2016 10:18 PM
Hey @themotors,
unfortunately, no, texting from outside Canada on a public mobile phone is not possible. There is no outgoing service provided outside of Canada.
you can only use the service inside Canada, but you can send internationally.
09-19-2016 09:34 PM
03-22-2016 04:58 PM
03-22-2016 04:43 PM
Thanks @Kalla_A, for confirming that international texting is available.
I understand that this was likely a glitch, but the point I was trying to make is that the error text that PM was sending @bradp36 is misleading and should be fixed. Instead of "Sorry, we do not offer text messaging outside of Canada at this time", which is false, it should be something like "Sorry, your plan does not support text messaging outside of Canada".
03-22-2016 03:00 PM - edited 03-22-2016 03:26 PM
