11-28-2023 09:24 AM
Hello all,
hoping the community at large can clarify a couple of points for me with respect to international minute add-ons… specifically thinking UK minutes.
1) are add-ons one time purchases, or are these recurring monthly additions to your subscription?
2) it’s suggested that unused minutes from an add-on such as this roll over to the next cycle. Do they continue to roll until entirely consumed or is it just this cycle plus the next? (Ie. you’d have to buy an add-on every two months to have minutes available every month)
any insight would be much appreciated!
thx
11-28-2023 09:35 AM - edited 11-28-2023 09:36 AM
@BWest wrote:Hello all,
As @Handy1 posted, addons are 1 time purchases. They do not get replenished at every renewal.
Minute addons (EDIT: with exception to Roaming USA addons) / 1000 U.K. Long Distance Minutes - $15 will last on your account for as long as it takes to use up the minutes. Note the 'fine print':"Calls made to numbers starting with the following UK codes are not included in UK calling from Canada and will not be completed when dialed: 4470, 44870-44879, 44843-44845."
Similar to #1, Minutes 'roll over' until all used up.
thx
@BWest - see above
11-28-2023 09:27 AM
That is amazing, and thank you so very much!
11-28-2023 09:26 AM
@BWest They are one time purchases and will roll over until all used up
