Changing subscription
Marts
Hello!
If choose to change my subscription à renewal, does it lock the promotion? Per exemple if I choose the 40Gb for $34 will it be lock or if it changes back to 20Gb is that what will be apply at my next renewal?
thank you!
Marts
Excellent! Thank you very much for your help!
Marts
Thank you!
@Marts  Yes it will. Locked  in and you can confirm it’s all set up in your payments tab like this
@Marts - you can plan to have a 'renewal change on your next renewal' and it should change on your renewal date, YES it will lock it in if the promotion/plan becomes no longer available.
But if you are asking that you can change or cancel the upcoming subscription change? Then yes, you can also cancel a upcoming subscription change as well.
