07-14-2022 12:51 PM
Will my data work abroad (not Canada or U.S.)? If not, is there an add-on I can buy to get internet while traveling internationally?
07-14-2022 07:20 PM
If you are travelling long term…month or more. It will be cheaper for you to pickup a local SIM.
Short term then a wifi phone/text app would be the way to go as indicated by others.
07-14-2022 02:09 PM
@channahfq You should be able to get inexpensive data plans where you are traveling. You can also try to get by with WIFI apps like Skype, Whatsapp or Textnow although that isn't always feasible without access to WIFI connection.
There's another interesting option that another user has recently posted about for data only SIMs from Keepgo here: https://productioncommunity.publicmobile.ca/t5/The-Lounge/PM-s-15-plan-with-the-cheapest-dual-SIM-E-...
07-14-2022 01:12 PM
NO. PM has service in North America only. No add-ons for service outside of this island.
07-14-2022 12:54 PM
No PM add-on will work away from Canada (or US without add-on).
If you'll have access to free wifi...consider free voip app like TextNow.
07-14-2022 12:51 PM - edited 07-14-2022 12:52 PM
@channahfq NO, there is no roaming other than US
you will have to buy local data prepaid sim there
