10-01-2022 11:36 AM
I was awarded 500 International minutes. My account says I have 387 minutes left. I never, ever made any international calls! I cannot find any usage charts or evidence that I made the calls from my number. Otherwise your service is great!
Hugh
10-01-2022 12:00 PM
If your regular plan only has limited number of calling minutes...those International calling add-on minutes will get used if you run outta regular plan minutes.
My suggestion is to either upgrade to $25 plan with Unlimited Canada calling OR get a $5 / 500 minutes of Canada wide calling add-on to supplement your limited calling plan...instead of using up your gifted international calling time.
10-01-2022 11:39 AM
We’re all your calls to Canadians phone numbers?
USA call counts as international calls.
Login to your account and check the history of your calls and check the area codes.
10-01-2022 11:38 AM - edited 10-01-2022 11:39 AM
What plan are you on? If you are on $15 plan then as you use your 100 mins add-on will kick in and start using minutes.
Try one of these suggestions to get real actual status of your account:
Try using different browser. Try Incognito mode. Clear browser’s cache. Try forced refresh.
