06-16-2021 05:45 PM - edited 01-06-2022 02:32 AM
I need phone records for my insurance. How do i obtain those for 3 days in may?
06-16-2021 09:27 PM
@Caper782 Yes, if all you are asking is just phone record, assuming you meant calls record, you can logon to My Account->Plan and Add-Ons Tab-> Usage History. You can get as far back as 3 months. you can set specific date range.
Unless you want official invoice, you don't really need to contact mod.
06-16-2021 08:34 PM - edited 06-16-2021 08:34 PM
@Caper782 : You didn't ask for an invoice. You asked for your records for a few days. You can find that yourself in the self-serve as already mentioned
06-16-2021 08:30 PM
Ive contacted a moderator to see about phone records and awaiting a reply
06-16-2021 08:21 PM - edited 06-16-2021 08:21 PM
Read this post by @AE_Collector on how to request an invoice from pm if you need an official reciept and/or a copy of your usage for those specific dates.
06-16-2021 06:27 PM
This is a unique need, and hopefully the above suggestions are good enough for your needs. If the history you see under My Account isn't everything you need, you can try reaching out to a Moderator (staff) for some additional help.
It's best to open a ticket through the SIMon chatbot (chat bubble, lower-right corner) because you can login and attach your account to the ticket. Otherwise, you can try and message them directly here too.
Hope all goes well! 🙂
06-16-2021 06:02 PM - edited 06-16-2021 06:03 PM
Log into your self serve account then under My Plan>View My Usage.
This will show all calls, text and data usage. There is a drop down menu for the last 7 days or 30 days.
06-16-2021 05:47 PM
You can log into your self serve account and search under usage history.
