06-13-2024
07:59 PM
06-13-2024
11:36 PM
computergeek541
We tried to port our number over to PM but we entered the IMEI number by mistake. We cannot finish the activation, any suggestions?
06-13-2024 08:04 PM
I’ll give it a try, thank you
06-13-2024 08:03 PM
hi @Ryan232759
this is the only phone number you will get but they only deal with porting problem, no other support issue
06-13-2024 08:02 PM
I thought PM was online only with no phone numbers?
06-13-2024 08:01 PM
Hi @Ryan232759
do not use IMEI, give PM support agent the account number of your old carrier
I have sent you the porting support team number. Please check your Community inbox (envelope on top right), check for the number and call and give them the info
