Incorrect ESN/MEID
TTdA
Hi.
I transferred my number from Fizz, and received the following message:
"Hey, it's Public Mobile. We're having trouble transferring your number. Looks like you entered an incorrect ESN/MEID. Someone from our team will contact you shortly using your original phone number or the alternate number provided. You can also get in touch via our virtual assistant at: https://publicmobile.ca.ada.support/chat"
I have not received any contact. I can not reach any one through the chat bot either. The account number for Fizz was too short so it would not accept it. So, I entered IMEI number instead.
Can someone help me?
7 REPLIES 7
Binhua
I have received same message,How do you solve this problem? I also need help ,thank you
@TTdA wrote:
eSIM is on Public Mobile, and physical SIM is on the old service provider, Fizz.
Interestingly, both data and phone work, but only Fizz's can receive and send text messages.
@TTdA
Then we can private message you the Telus team porting number.  Check your private message inbox.
TTdA
Yes, I did.
Did you say YES to the port request from Fizz? WIthin 90 minutes...
TTdA
Dunkman
@TTdA
Did you activate eSIM versus physical SIM card?
What happens when you put your SIM card in the phone?  Any service at all?
Chalupa_Batman
Hey @TTdA  We're all customers like you. You have to reach out to a CS Agent to resolve this.
To submit a ticket, start with the chatbot at the bottom right corner.
Or the following link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
