03-05-2023 05:01 PM
Payment did not go into my account. Can't access my account
Payment
03-05-2023 06:01 PM
Thank you
03-05-2023 05:54 PM
hi @mtlurbaniste wait and hour and try again. Start with using *611 to pay if you remember the 4 digits pin. if not, then try My Account again
if you still unable to pay and resume services after the one hour wait, please submit ticket with CS agent
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
03-05-2023 05:45 PM
I have the same problem. Automatic payment did not go through for some reason, account deactivated instantly, tried multiple times to make payment online but would not go through. Seems like issue on Public Mobile end.
03-05-2023 05:05 PM
If you have been in nonpay/suspended status for over 90 days, or ported your Public Mobile number to another provider, then you lost your Public Mobile account, phone number, and access to My Account.
When was the last time you had active services, and have you ever created a My Account before? If not and you are a current customer (have been active within 90 days and have not ported out to another provider), you can submit a ticket here to: Create or forgot My Account email or password link
If you have created a My Account and you are having issues logging in, try clearing your browser's cache, or try a different browser or device. Opening a tab in incognito mode may help as well.
03-05-2023 05:03 PM
Auto pay can fail
To make payment and reactivate plan .. if you know PIN number you can *611 with a voucher and *611 no PIN needed . You can also do this by by calling 18554PUBLIC . otherwise log into self serve make manual payment and reactivate service and or update credit card if necessary
My account
Legend and features
Change plan / update cc /auto pay
Account #/ change # port /swap SIM
If you still have service and your plan renews today / tomorrow you can ignore this suspended notice
03-05-2023 05:03 PM
@D_F you had service couple days ago and just had problem with renewal??
if you cannot access My Account to make manual payment, submit ticket to cs agent
First type Forgot Login,
