If I get US roaming add-on, can I call Canada from the US?
aabasiry
Hi,
Planning to travel to NYC and I would like to buy the US talk/text roaming package. While in the US, can I phone Canada? and of so, will there be any extra charges?
Thanks
aabasiry
Thanks fellas..
I don't need data, just talk and text.. So, the $15 it is..
Cheers..
@aabasiry
The bundle includes calling, texting and 3gb of data for $30.
For calling and texting without data for $15 to Canada or USA.
Remember to connect to AT&T or T-Mobile network for roaming to work.
@aabasiry wrote:
Thanks for the replies. So, only the talk/text/data ($30) package allows calls to Canada but not the talk/text ($15).
Did I understand that correctly?
Thanks again..
Nope...if you only get the talk/text roaming add-on, that will allow calls to Canada and US as well...just no data with that package.
aabasiry
Thanks again..
@aabasiry
You can make an Add-on purchase online.
$15 for talk & text to Canada or within USA.
You can also use WhatsApp or TextNow app for free calling and texting to Canada on wifi.
hairbag1
@aabasiry
the 15 Day US talk/text/data roaming package allows calls to Canada and US,,,no addition costs. Ensure your phone is volte enabled for best talk ability.
sp
