05-16-2022 02:41 PM
I tried to get my phone number transferred from Bell. I got a message saying I had entered the wrong ESN/MEID I understand that is the same as the IMEI. I don't know how to go back in and check that the number is correct. I got a text from Bell asking if they could transfer it - so they must know it's me.
Joining Public
11-26-2023 12:59 PM
hi @Lilinaw
I will send you the number
11-26-2023 12:57 PM
i have the same problem can I have phone number too
05-16-2022 06:45 PM
Thank you so much
05-16-2022 06:40 PM
@Julie13 There is a number you can call and can talk to live person , you can then give them the account number and other missing information. I will private message you the number. Please check your Community inbox on the top right
05-16-2022 06:33 PM
How do I get back to where it asks me to put in the number?
05-16-2022 02:49 PM
The account number is a lot less hassle, it seems the porting issues usually have to do with the IMEI and that the account # is preferred and doesn't hit the same snags
05-16-2022 02:43 PM - edited 05-16-2022 02:45 PM
ESN/MEID isn't the same as IMEI, but you're correct that Public Mobile means IMEI. For transfers from Bell Mobility, the account number should be used instead of IMEI.
