I
12-29-2023
08:04 PM
12-30-2023
07:44 PM
computergeek541
12-30-2023 05:04 PM
Incorrect solution removed
12-30-2023 11:03 AM
@softech Appreciate you taking the time to correct me and not correct the improper solution , very kind of you
12-30-2023 10:43 AM
if OP accidentally changed the number, the old number won't be available in the pool to choose from for at least a month. Of course, if the number was ported into PM, it won't even come back to PM/Telus' pool at all
12-30-2023 05:14 AM
12-29-2023 08:18 PM
Today about 6 hours ago
12-29-2023 08:12 PM
how long ago did you do this ?
12-29-2023 08:10 PM
@Bubble1 You can message support and see if it still available . Hopefully it originated in the Telus family or not it will go back to the original carrier
send a private message To CS_Agents
while waiting for support you can keep refreshing the page of phone numbers to look for it in your account profile page . Also note you can change your phone number 4x for free every 30 day cycle
Change # on profile tabs
