11-23-2019 01:18 PM - edited 01-05-2022 08:06 AM
I will be traveling to us can I buy roaming ?how much?
11-23-2019 02:11 PM
@buiya wrote:
@hairbag1 wrote:
@Raf414 wrote:I will be traveling to us can I buy roaming ?how much?
The only options that Public Mobile has for you is the 10 Day US Talk/Text/Data options. Be aware that your 10 days start as soon as you hit "Buy"...so plan ahead. If you buy it at 10pm...that's day 1.
U.S. Talk, Text and Data BundleU.S. Talk and Text BundleU.S. Talk OnlyU.S. Text OnlyU.S. Data OnlyIs a 24 hour period for each day? So in your example, if you click buy at 10 PM that's day 1, does it end at 10 PM on day 10 or 00:01?
If you bought it at 10pm...then at midnight starts as day 2. Plan your purchase carefully.
11-23-2019 02:08 PM
11-23-2019 01:55 PM - edited 11-23-2019 02:08 PM
11-23-2019 01:43 PM
Dunkman has stated the solution perfectly!
11-23-2019 01:25 PM
You can buy 10 day USA roaming add on from your self service account or dialing 611 on your phone. The add on starts when you purchase it. It is a 2 step process. Load funds and the purchase add on
