I want to retrieve my old number
a week ago - last edited a week ago
Hello I want to retrieve my old number 236 *** **15, is there a way to do this?
Service
a week ago
You really shouldn't post your number on the fourm as anyone cans see it. Even though it's not your number at the moment it my be if pm can help you. Use the v icon on the right of your post to edit.
a week ago
a week ago
@marangoni You may be in luck. I called the number and it is not in service so I would think that increases your odds of getting it back.
a week ago
Oh okay, thanks @slusagm ! I am doing this right now.
a week ago
just check again, 236 996 is a Telus number in Vancouver, so it will work in PM
if you had the number before and if you lost the number for 6 months, there is a chance PM can assign you back the number, but of course, you need to prove them you owned it
a week ago
was the number ever with PM or Telus? I just tried and it said the number won't work in Telus network
but you can ask PM to confirm
a week ago
Hello @kb_mv , thanks for the quick answer. Its from New Westminster, its aproximatelly 6 months old, so that is why I dont know if it's still available. I will send a message to them, thanks!
a week ago
@marangoni It depends on a few things. Where is the number originally from? How long has it been since you had the number? Customer service may be able to help you depending on your answers to above. Send them a message at https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
