08-06-2015 11:19 PM - edited 01-04-2022 01:52 PM
I tried to change my password fo take my messages for my voice mail, but I failed, can you please help me \
thanks
08-07-2015 01:31 AM
You can reset your voicemail password by calling *611 from your cellphone
OR
From your self serve account here.
https://selfserve.publicmobile.ca/Overview/plan-and-Add-ons/reset-voicemail-password/
08-07-2015 12:02 AM
Hi. If you-Into your Self-Serve Account, click Plans and Add-Ons, you'll see Reset your VoiceMail Password. Click that, and follow instructions. Your Voicemail password will then be Reset, and you can then go back in and create a New Password
