I purchased a duplicate add-on
radar_ca1
I purchased a duplicate add-on and need to remove one.
HALIMACS
@radar_ca1
Just to provide you some expectation, what public mobile will likely do is credit the amount of the extra add-on to your available funds so it can be used for future services. (cycle renewals or other add-ons)
They will very unlikely refund it to the payment card.
radar_ca1
Thank you.
@radar_ca1  You need to submit ticket with support and see if they can reverse it for you
private message   To CS_Agents click
@radar_ca1
If it was an honest mistake, PM support likely able to reverse one of those transactions. Just message them here
