02-01-2021 01:30 PM - edited 01-06-2022 01:59 AM
02-01-2021 03:01 PM
@Gogozeno If by Suspended, you mean you can't call/text, then I just remembered you should try calling 611. If that fails, there are two possiblities:
02-01-2021 02:55 PM
@Gogozeno If you have autopay with a valid card, or paid in full, but have no service, you likely need assistance from the moderators.
To get a ticket click https://widget.telus.tiia.ai/publicmobile/publicmobile.html and enter your question into SIMon. Invent prompts until you get to the Contact Us button, click it and a Submit Ticket button should appear. Click it then login and pick the topic, if needed, from the drop down menu. To confirm your ticket has been submitted, check the SENT box in your private messages; click the small envelope beside your avatar at top right on your screen.
While you're waiting check out the workarounds in this post: https://productioncommunity.publicmobile.ca/t5/Paying-for-your-service/SOLUTION-My-plan-has-enough-f...
Just in case response is very slow and the workarounds fail, engage a backup plan. Mine is using fongo.com over wifi, but I think Textnow is currently slightly better as they include SMS.
If you encounter problems submitting a ticket, you can send a private message to Moderators here https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437, but this alternative method may have longer response time.
02-01-2021 01:33 PM
Which plan? What is in your Available Funds? What happens when you click on the Reactivate button in the upper right area?
