I need to transfer my plan
sabamobile
I need to transfer my plan to my family member please call me 647 xxx xxxx
edit: ph removed by NDesai
2 REPLIES 2
Naepalm
@sabamobile
Lets see if this sticks...
You can give the SIM card to a family member and they can take it over that way. Give them all the login details and have them change the information in your self serve account.
All they would have to do is insert the card into their phone.
Have a great weekend!
NDesai
@sabamobile You cannot transfer accounts. What you can do is change all the details to your family member. If you are looking to keep your phone number, then this is not possible because the account will be deactivated when you port out your number.
