04-04-2023 05:16 PM
I just purchased add on for US roaming
i thought it was 15 days of calls/ texts
does it mean the rest of my usual plan minutes or unlimited minutes while in US? Because my current Canadian plan has 100 mins and I have used almost half of it already.
04-04-2023 05:47 PM
Are you saying that when you make calls in the US that minutes are being deducted from your 100 minutes? That is most definitely not supposed to happen. Or are you in Canada? Or is this a roaming re-buy?
04-04-2023 05:45 PM - edited 04-04-2023 05:46 PM
When you are in the US and connected to T-Mobile with a US add-on, neither calls nor data are reduced from your regular plan allotment.
04-04-2023 05:21 PM
@Azhokasuper wrote:I just purchased add on for US roaming
A U.S. roaming add-on that includes talk and text includes unlimted usage for both while you're in the U.S.
