Unable to sign in to Public mobile account / will new phone activate automatically?
toast
I bought a new phone and I'm trying to switch my SIM card over to it, but I thought maybe I should check my Public Mobile account first. Well, I'm unable to sign in and I've been given the following error for the past hour or so:
"System error. Please try again."
Is there a system outage?
Also, will my account and SIM automatically register/activate with the new phone, or do I need to perform some sort of special action with my Public Mobile account? I bought a Samsung S22 from the store awhile back, if that makes any difference.
8 REPLIES 8
toast
Call forwarding when unanswered / unavailable. Is that what you mean by Conditional Forwarding? How long has this problem been going on? I need this to forward calls to my voicemail service (not PM's) 😕
EDIT: conditional forwarding seems to be working, but I have a separate issue, so I'll open a new topic instead.
@toast Calling forwarding all should work, but Conditional forwarding should still be broken.  Waiting for PM to fix
toast
I moved my SIM to my new phone and I'm able to call out but when I try to change settings like Call Forwarding I get an error: "Failed to read data: Something went wrong. Check your SIM card or network connection, then try again." Any ideas?
@toast
All your account information is all in the SIM so it will work if you put the old SIM in the new Samsung S22 but you might have to remove the (standard or micro) spacer on the SIM to fit the nano size SIM tray.
Community_QA
@toast just move your old sim to the new phone, it will work
keep the new sim for future use, in case this old one fails one day, or give to freind
jessicadtoste
Check if you need to make any updates on your phone
Dunkman
@toast
You should just be able to move the SIM card from  your old phone to new phone.  No special things needs to be done.
As for your self service account, it can be finicky.  You should try again with a different web browser, clear cache or incognito mode.  Or try to login with a different device.
will13am
@toast , you can move the SIM card from phone to phone as much as you like without having to do anything in your online account.  As for the access problem, please try using incognito mode on the browser to see if that helps.
