I need network
mugisha2016
My account is active but no network service
10 REPLIES 10
@cellphoneuser1
I know that....which is why I gave an example of the screen in case the OP was confused.
@darlicious The PUK was asked for. The PUK isn't 1234.
@mugisha2016
Is this the screen you are getting? If so the default code is 1234.
Spudster
@mugisha2016
You need the moderators to assist with this.
To contact a moderator, there are 2 methods:
  1. Use the ticketing system for a faster response time. Click here and type moderator, then select contact moderator, then select other (or the topic that more closely matches your request).  Click the result which states Click here to submit a ticket and follow the prompts,  or,
  2. Send a private message to the moderator by clicking here  You’ll need to be logged into your Community account for the link to work.
Here is an explanation by one if the Oracles, Luddite.
SIM network PIN blocked. Enter SIM network PUK." is asking for the phone’s (often Samsung) “master code" after entering the wrong code too many times. Samsung and/or your previous carrier can give you this.
"SIM network unlock PIN" is asking for your previous carrier's unlock code - just contact them with your IMEI and they'll give it to you. If you enter this incorrectly too many times, you'll get the error message above.
“PIN unlock key (PUK)” is a SIM-specific code used to prevent unauthorised use of a SIM card.
The PIN (Personal Identification Number) enables secure access to the SIM card and network. It is provided with your SIM card.
  • If the PIN code is entered incorrectly 3 times, the phone is locked (except for emergency calls) and requires a PUK (Personal Unlock Key) to reactivate it.
  • Once the PUK is recovered and validated, you will be asked to choose a new PIN.
  • Only Public Mobile's moderators can give you this type of code, which the device manufacturer cannot. Public Mobile's moderators can be contacted at the following address: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
  • Caution! If the PUK is entered incorrectly ten times in a row, the SIM card becomes unusable.
 @mugisha2016 : Did you put a different SIM in and then this SIM back? It sounds like you set SIM security on your phone. If you can't remember the code you used for that then you'll need to contact the moderators.
mugisha2016
They ask me PUK code
mugisha2016
I tryed every thing but still show Sim locked
Triguy
Try rebooting your phone.  Also try putting it in airplane mode the back to active.  If you have another phone try swapping the sim.
 @mugisha2016 : Calls in/out? Texts in/out? Browse internet?
