I need a new esim
Auctoris
My account does not work I need a new esim. How can I get a new one from customer service?
caroline
@Auctoris  Try this link then
private message   To CS_Agents click
@Auctoris  Also is the iPhone a XS and later ? Anything iPhone  before that is not eSIM compatible . If you accidentally deleted the eSIM you would need to get a physical SIM card to replace it
Auctoris
This solution does not work
@Auctoris Please
message support directly
  • while your already here and logged in the community you can send a private message   To CS_Agents click >>>here.<<<
Auctoris
The email does contain the code but it does not work. My iPhone says it can’t isnstall it and there is no way I can contact customer support. I tried everything, I am desperate that I lost my phone number.
@Auctoris  Check you welcome email from PM the QR code should be there . And scan it . If you need further  help from support please
