Plan change
HP10
@CS_Agent
I submitted for a new plan that was on special that was to start today and it didn't switch over or charge me the new rate.
It was 39.00 a month if I subscribe for 3 months at a time and included 30GB a month.
2 REPLIES 2
HP10
Thanks but that isn't working I was charged my old rate when my plan should switched to the new plan and rate today. Will contact cs directly
@HP10  First check like this
Try again incognito/private mode
And or lap top /computer
                    OR
simply try refreshing the page to check data plan / mins / add ons
if it’s not right please to get fixed
message support directly
while your already here and logged in the community you can send a private message   To CS_Agents click
adding if you were charged $117 that would be good evidence your on the right plan $39x3 =$117
@HP10
