04-20-2023 03:14 PM
We just signed on from Koodo not prepaid and it’s been 2 days and our cells have not switched over!
Can someone please help?
04-20-2023 05:12 PM
Common mistake with new members is NOT to reply with YES to the text confirming you are porting over to PM with the old SIM in the phone. There is a 90 minute timeframe for you to reply or the porting will be cancelled.
Your Koodo SIM should still work if porting is not completed.
Just contact a CS_Agent to restart the porting process for you again.
Submit a ticket on SIMon Chatbot bottom of page or private message on the envelope icon above.
If you did reply, just reboot your phone by powering off then back on.
04-20-2023 03:17 PM
@HKL51 first, is it just incoming calls on your PM sim card not working?
can you make outgoing calls?
if you outgoing calls are working and just not incoming , there is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
04-20-2023 03:15 PM
Did you leave the Koodo sim in a phone to confirm the transfer? Can you call out? Text in and out? Use cell data?
