I missed the transfer phone number verification text
tonidkearney
I accidentally deleted the transfer request phone number verification text. I’ve got a new carrier and am moving over my current phone number. How can I get this text resent to me again?
8 REPLIES 8
earlngladys
I too missed the transfer verification text and it has expired. How can I get this text resent to me again?
@softech wrote:
@LitlLdy   No, that only for porting in
Somehow I was assuming it was porting in.
If it is porting out of PM, then the new provider should be contacted to re-trigger the porting request
@softech , possibly, I may have read it wrong “I’ve got a new carrier and am moving over my current phone number.
@softech wrote:
@tonidkearney
no worry, There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
@softech , will that work when porting phone number out of Public Mobile?
@tonidkearney
You contact the carrier you are moving your number to so it sounds like you got a new carrier then talk to them.
If you are moving to PM then contact a CS_Agent.
pmbc
@tonidkearney are you porting to PM or from PM?
Do you recall which number the message is stated to have came from?  If it's still within 90 minutes, you could send a text message that says YES to that number.
@tonidkearney
