I made a mistake with esim
tina_l
When I tried to subscribe to public mobile and went through the process I went with esim because I thought my phone could do it. But I found out later that it doesn't support esim and I started the process with esim and now stuck. Can anyone help me?
CSA_PM
Customer Support Agent
Hello @ tina_l,
I sent you a private message. You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
tina_l
Hello @CSA_PM I sent you a private message. I got a physical SIM card. What do I do next?
CSA_PM
Hello @ tina_l,
You’ll need to purchase a physical SIM card. You can buy one from a nearby store or order it online from Amazon. Once you have the SIM card, send a private message and we’ll complete the activation for you.
tina_l
I will purchase a physical SIM card. Another problem I'm having is that the number has been ported to public mobile and now I don't have access to that number because I'm half way through the process of subscribing to public mobile. How do I undo this mess I made?
Dunkman
@tina_l
You will need to purchase a physical SIM card and contact need to contact customer service agent.  I will try to escalate your post to CK_PM.  They should private message you directly within 0.5-1 hour.
