I'm traveling in the US. I have added text and talk. It is not working. Some calls come most dont. P
06-24-2024 09:28 AM
07-02-2024 06:25 PM
Thank you. that seemed to be the issue. Your right very spotty.
07-02-2024 06:24 PM
Tried that didn't work.
06-24-2024 09:40 AM
Is both text and talk not working?
Might want to try a simple reboot of your phone. If that does not work, network reset of phone (note: this will erase any saved Wifi passwords).
06-24-2024 09:37 AM - edited 06-24-2024 09:40 AM
@barelymine What phone do you have, is it on PM's VoLTE list (scroll down to the bottom of this page:
https://www.publicmobile.ca/en/on/get-help/articles/volte
If the phone is on the VoLTE list make sure you're not trying to connect on 5G, drop the phone to 4G/LTE. It should be connecting to either T-Mobile or AT&T, if one is not working try the other (you'll have to set the phone to manual connection instead of automatic to see the carrier options). If your phone is non-VoLTE then try T-Mobile's 2G network which still exists but can be spotty. Put data roaming on even though you don't have a data add on, it may be necessary for VoLTE to work.
Edited to add, if you still have the S10 that you mentioned in a previous post then it is not VoLTE enabled by Public Mobile so your only option for voice calls will be T-Mobile on 2G.
