04-21-2022 08:39 PM - last edited on 04-21-2022 11:16 PM by computergeek541
I'm on the $25 plan with autopay. It looks like l've used up 500 mb of data and now I have no more data. It looks like my account doesn't recognize that I have autopay turned on. Thanks.
04-21-2022 09:26 PM
If you need a bit extra you can always buy a data add on to have the times you hit your 1GB and need a little to bring you to next renewal
04-21-2022 09:26 PM
Hi @sparkaction you can get a 1GB add-on and see if it is enough for you the use till next cycle. good think for add-on is that if it is not fully used, it will roll over to next month.
04-21-2022 09:25 PM
It's quite an honest error, @sparkaction
Navigating PM's usage history pages is futile and frustrating. It's very poorly laid out and non user-friendly sorting options.
04-21-2022 09:17 PM
It looks like I made a mistake using the Usage History function and I've used up 1 GB of data. Thanks for everyone's assistance.
04-21-2022 09:03 PM
You really need to use this resource, @sparkaction , to establish whether you've used your data bucket:
04-21-2022 08:57 PM
@sparkaction wrote:Under usage history it looks like I used up 500 mb.
@sparkaction - the usage history can be cumbersome to go through. Are you going back to the start date of your last renewal date?
And make sure you see those numbers at the bottom to scroll through...Clicking on the one by one maybe your best option for chronological usage....rather than sorting by "Usage Type".
04-21-2022 08:56 PM
I might be wrong. I didn't click 30 days for usage history. I will need to add up my usage again. Thanks for the help so far.
04-21-2022 08:54 PM
@sparkaction wrote:My Plan says 500 mb + 500 mb at 3G speed. When I go to autopayments it shows my card number with **** and i have the option to "Remove Autopay".
@sparkaction - that 2nd 500 mb...is your Autopay data bonus.
Okay, so you are receiving what you should be then. How do you know you only used up 500mb? Are you adding up in your usage, or something else...like the data reader on your phone maybe? Which needs to be set to match your start date of your plan to be accurate.
04-21-2022 08:54 PM
04-21-2022 08:53 PM
Hmm? When you changed the plan did you select the auto pay option on PM self-serve?
04-21-2022 08:52 PM
@sparkaction - if you have no more data left showing in your overview section of your self serve account, then how do you know you didn't use up the whole 1GB, since the line it would not be showing any longer if fully consumed.
Under your Plan Detail section what does it say:
https://selfserve.publicmobile.ca/Overview/plan-and-Add-ons/ChangePlanLandingPage/
04-21-2022 08:52 PM
04-21-2022 08:49 PM
I signed up about 3-4 months ago on the $10 plan and this is my first month on the $25 plan.
04-21-2022 08:42 PM
What does your overview page under my data & add-ons show? Does that page also show that "dynamic autopay" is on.
04-21-2022 08:41 PM
@sparkaction Are you on a older plan? When did you sign up?
