06-06-2020 02:24 PM - edited 01-05-2022 11:02 AM
06-06-2020 04:06 PM
06-06-2020 04:03 PM
Thank you!
06-06-2020 03:22 PM
Since you are planning to switch to a BC number after coming back, you can remove your autopay cc from your account and let it expires. 90 days after suspended, your account will be canceled.
If you have refer-a-friend and loyalty rewards, your reward will be gone with your canceled account. 2 options if you want to keep your account going:
Option 1: You can switch to the $15 plan and renewal every 30 days and let your reward to subside your plan cost.
Option 2: You can stop paying your fee on your next renewal date and renewal before 85 days after suspension. Remember to reactivate you account nbefore 90 days deadline. Otherwise, your account will be canceled and your rewards will be gone forever.
06-06-2020 03:08 PM
@jiyeong6766 One more thing to consider is that if your plan is grandfathered and not offered anymore don't switch plans just renew it on day 85, that way you get to keep your plan when you get back.
06-06-2020 02:37 PM
@jiyeong6766 you could switch your plan down to the lowest plan the $15 one, just before you leave the country. Remove your autopay credit card and you then have 119 days to reactivate it. Log into your self service account with 4 days to go and reactivate your account by applying payment. You then have another 119 days. You should be back before then. A couple of days before coming back. Apply paymemt, reactivate your plan and change your number to the B.C. one. You can also switch it back to the plan that best suits you. Enjoy your trip. Stay safe
06-06-2020 02:35 PM
@Triguy no need to set phone as lost, as that starts the 90 days. you only need to set lost stolen to stop accounts from renewing if they have funds > than renewal cost (and of course disabling autopay).
06-06-2020 02:33 PM
@jiyeong6766 this is a good read. https://productioncommunity.publicmobile.ca/t5/Paying-for-your-service/Extended-Absence/m-p/142735#M...
yes you can get more than 90 days by renewing before the 90 days to reset the counter.
06-06-2020 02:30 PM - edited 06-06-2020 02:56 PM
After 90 days without payment then your account would be deactivated and you would lose your phone#. You add back your credit card/Visa debit then switch to the $15 plan before 90 days and setup autopay for 3 months.
06-06-2020 02:25 PM - edited 06-06-2020 02:30 PM
@jiyeong6766 hi I am sorry but 90 days suspension and then your account is closed for good you could go to the lowest plan and just renew it before 90 days that will give you another 120 days and yes you can change your number to wherever you like
