I just sign up a plan but can not get sim card
yys2000
Due to Canada post strike.
i want to change to eSIM but no response from support.
any thoughts?
thanks
yys2000
Oh I can buy it from Telus store? I just passed by one today. Will go and check tomorrow, thanks
Chalupa_Batman
any thoughts?
thanks
Hello @yys2000
I see you want to change to an eSIM?  Because you already ordered a SIM card, only a CS Agent can change that. So because it's the weekend, support take a bit longer to respond. Keep an eye on this link for their response.
hi @yys2000 PM will ship using another courier during that strike.
but if you can , I suggest to buy it  from Telus or Koodo or Mobile Klinik stores or via Amazon:
 Telus or Koodo or Mobile Klinik store https://www.publicmobile.ca/en/on/pick-up-SIM
Amazon.ca https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/
