I have NO SERVICE
Susanq
WHATS UP?!
Rastin
Two ways to cancel one log into the app and Unsubscribe and your account will close by it self 90 days after your last payment cycle. Or two port your number to another provider and it will close automatically once your number is gone.
@Susanq   Check the Telus outage map
https://www.telus.com/en/outages
Porting out to another provider requires your PM account to be active and may take several hours and things can go wrong, best to contact customer service as @hTideGnow advised if it still doesn't work after trying the suggestions.
Susanq
Nothing is working. Reset does not work, account is up to date. There is no reason for this disruption. NONE.
@Susanq wrote:
I am travelling this weekend and can't NOT have service.‌‌
I am looking at other providers now.
How does one cancel this Public Mobile Service?
hi @Susanq
if you are travelling this weekend, it is better for you to get this resolved with PM before the trip.  Changing carrier might give you more trouble.
Try what I said above or open
HI @Susanq
new activation or old?
you need to tell us more for us to help
did you try the general thing?
1. check if your account is paid and active.  Login My Account and check
2. reboot phone
3. click Reset all network
4. change network mode to different one and test, 4G/LTE and 3G , try both
5. test sim in another phone
or of course, you can also ask support agent to help
 please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
Susanq
I am travelling this weekend and can't NOT have service.👎
