12-21-2019 07:34 PM - edited 01-05-2022 08:38 AM
12-21-2019 09:07 PM
@Jaydog wrote:I cannot sign in either. Have tried reset password many times. Doesn't work. Even waited well over an hour. I get the reset email (always two of them), click the link, reset the password and then I cannot log in
Create a moderator support ticket for help using the ? button at the right side bottom corner of this page.
12-21-2019 08:55 PM
12-21-2019 08:31 PM
@popping wrote:If you activate your plan online, your self-serve account is already created. Use your email address as username and your password you supplied during activation to loggin self-server portal https://selfserve.publicmobile.ca
If you activate your plan in-store, follows your welcome email to create your self-serve account. You need your PM phone to receive a 6 digit code text message.
https://selfserve.publicmobile.ca/self-registration/
If you forgot your password to your self-serve account, try the forgot your password linkon hte login page. If this does not work, create a moderator support ticket for help using the ? button at the right side bottom corner of this page.
I tried the forgot your password link on the login page. I received the PM reset eamil in 30 minutes.
12-21-2019 07:50 PM - edited 12-21-2019 07:51 PM
12-21-2019 07:40 PM
Try using a different browser and incognito mode. Also clear your cache and cookies then reboot.
12-21-2019 07:37 PM
First, try the account reset function here: https://selfserve.publicmobile.ca/forgot-password/.
If that fails, you will need to submit a ticket. To get a ticket: click https://publicmobile.ca.ada.support/chat/ and enter your question into SIMon. Follow/invent prompts until you get to the Contact Us button, click it and a Submit Ticket button should appear.
