02-28-2021 10:42 AM - edited 01-05-2022 05:27 PM
I changed my plan but click to move forward without using the promotion code, what shall I do? Can I move backward and put in the promotion code?
02-28-2021 01:42 PM
@Lisazheng1022 :Since your question about the promo code has been answered, you should mark this thread you created as solved by clicking on the accepted solution button above one of the replies posted above that helped you most, doing so will help others with same question in future.
02-28-2021 10:47 AM
@Lisazheng1022 wrote:I changed my plan but click to move forward without using the promotion code, what shall I do? Can I move backward and put in the promotion code?
Hi @Lisazheng1022 ,
There are currently no promos to use (that I heard of) when changing plans. All promos have been for new activations/customers lately.
I believe you are referring to this Promo box showing below? Nothing to enter in this field at this time.
02-28-2021 10:46 AM - edited 02-28-2021 10:48 AM
The promotion codes are only able to be used on NEW activations. If you are activating a NEW plan, and forgot to put in the activation code on a prior screen, I would recommend completing the process, then Private Message the moderators to advise of the promotion code after completing the activation process.
If you're simply changing from one Public Mobile plan to another, there are no promotions to go along with that.
