I cannot receive text message
LuciaZhang
I changed a Moto G Pure today, but I cannot receive text message any more.
Did you previously have an iphone using this number?
LuciaZhang
My husband send IMESSGE . this is why i cannot receive message. He should sent as a text message.
Many thanks!
LuciaZhang
Thank you so much for your prompt response.
I found that my husband send me IMessage.( Blue). changed to send as a text message. it works now.
Much appreciated all your solution.
This is my first time come to community and I never thought it works so quickly and faster.
All  you have a good evening!
@LuciaZhang - Can you send text messages? And does calling and data work?
Try resetting your network settings.
Settings icon > scroll to and select System > Reset options > Reset Wi-Fi, mobile & Bluetooth Reset settings > select Reset settings again to confirm.
Note: Resetting your network settings deletes previously associated Wi-Fi networks, security passcodes, Bluetooth devices and cellular network data settings.
EDIT, I wonder if this has anything to do with the messaging app you are using? Perhaps not, but just throwing it out there.
https://www.verizon.com/support/knowledge-base-239613/
hairbag1
@LuciaZhang
texts from only one person or any texts not received ?
