05-06-2024 07:22 PM
05-06-2024 07:28 PM
@Pat1985 - Do you have a data blocker enabled? Please disable it. Also enable cellular to use data on your Public Mobile plan within your phones settings.
If it doesn't work, maybe try the APN settings to be this:
On iPhone set it to sp.mb.com
Or within this help article for android devices:
Next, check your APN settings (Android Phones Only):
Also try the SIM card in another phone / device, if it does work then it is your phone's SIM tray / reader, but if it doesn't work please contact CS_Agent:
Submit a ticket via Chatbot:
⬇️ Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
