09-20-2022
08:25 AM
09-20-2022
08:26 AM
computergeek541
I just switched to public mobile. I thought it was good because I could make outgoing calls but when my son and my daughter tried calling me, it goes straight to un
09-20-2022 03:22 PM
@not-trust-anyon wrote:open ticket with PM support and ask them to check it for you
At https://publicmobile.ca/chatbot.
Start by typing Submit a ticket, then click Contact Us, Then click Other, then click Click here to submit a ticket
have trouble with Chatbot: private message CS_Agent at:
https://productioncommunity.publicmobile.ca/t5/notes/composepage/
Once ticket is submitted,(envelope icon on the top right) CS_Agent will reply you there
Without knowing how long before starting a thread the customer waited before starting this message thread and without know what happened after, opening a ticket would be premature advice.
09-20-2022 08:33 AM
hi did you leave your old sim in to receive transfer request,you have 90 minutes to reply yes I will PM you the number to call to reinitiate port request
09-20-2022 08:28 AM
This means that porting has not been completed. Please continue to use the old carrier's SIM card. A text message also needs to be repljed to for number porting approval.
