a week ago
11 hours ago
the servicemen restarted the system of my account service and I can use my text message. thank you
a week ago
@Timwan Is this all text messages including SMS or just picture messages? There was an issue with SMS messages for new customers a little while back but it's supposed to have been resolved. If you're still having the problem submit a ticket at the chat icon bottom right of this page or, if that doesn't work, send support a private message using this link
a week ago
as said, start with Reset all networks and download Google Message and use as the default messaging app
if that does not work, it could be an APN problem. But there might be a bit more work than simply updating. Many confirmed that you need to delete the current APN profile first. Then Add new profile and add according to the following. Please note case-sensitive and do not add extra spaces. Remember to save the new APN and then reboot the phone before you try
APN: sp.mb.com
(or try all upper case SP.MB.COM)
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
a week ago
i have tried all the above but doesn't work
a week ago
I can receive incoming calls and make call without problem. my cell phone is xiaomi13.
a week ago
can you receive incoming calls? and you can make call without problem?
for text, first, what phone do you have?
first, try Reset All Networks or Reset Network Settings on your phone
And if yours is an Android, make sure you have the latest OS Update. Then, try download Google Message, set it as the default messaging app and test
If yours is an iPhone, make sure iOS and Carrire profile are both updated
