I bought the wrong add-on
mandadc08
I bought the wrong add-on. I wasn't aware that data now expires after 30 days. In this case, I'd only need to buy 200 mb. Can it please be refunded or adjusted? I can add the 200 mb if that is easier. Thank you in advance.
2 REPLIES 2
@mandadc08
PM is prepaid provider and usually do not provide refund
but if it is an honest mistake, PM support usually can reverse the transaction and put the money back to your My Account, you can then use the money to re-buy 200MB data yourself.
Please open ticket by messaging them here:
@mandadc08  If you just did it by accident and not used any of it please message support to see if they willing to reverse it for you
message support directly
while your already here and logged in the community you can send a private message   To CS_Agents click
