07-13-2020 07:06 PM - edited 01-05-2022 12:05 PM
07-14-2020 01:21 AM
So what do you want to do with the "inactive" one?
Why do you have it? Why _did_ you have it?
Does it have a balance in Available Funds?
07-14-2020 01:05 AM
@Iamthememe_ , the question for you is, do you truly need to have two accounts or can you get by with one. Is the second account on delay because of the shutdown? And when Phase 4 is in place or everything is back to normal, do you think you need a second account?
Personally, if you the second one is on hiatus because the Covid-19, I would change the plan to the lowest plan available ($15 a month), and take off autopay. Of course, if you already have funds in this account, Public Mobile will take whatever funds that you have and exhaust that until your account is paid. If no money or funds are in your account, your account will be suspended for 90 days. Go back into the system, and renew your plan about day 85 and repeat the same process, every 85 days (not 90 days, just in case issues!). We are at Phase 3, so, unless we see another major wave, we should be close to Phase 4!? And you wouldn't have lost anything such as a phone number, or SIM.
On the flip side, if the second account is no longer necessary for whatever reason, again, cancel the autopay. If any funds in the account, Public Mobile will exhaust that. Or you can ask SIMon to cancel your account forever. Which also means, that phone number is now up for grabs.
07-13-2020 09:05 PM
@Iamthememe_ If you have both SIMs, install the one for the account you don't want; dial 611 and cancel autopay.
07-13-2020 09:01 PM
Choices to cancel service:
1. Quick and keeping your phone number (This choice does not apply to you)
Remove autopay credit card info to stop autopay and port your number to another provider. Your account will be canceled right away.
2. Slow and not keeping your phone number.
Remove autopay credit card info to stop autopay. Your account will be suspended without payment at your next renewal date. 90 days after suspension, your account will be cancel. You have 90 days to change your mind by paying and reactivate your account.
3. Make money and not keeping your phone number
If you have a plan with high demand, you can let someone to take over your plan. Your phone number will go with the plan to the new owner.
07-13-2020 07:36 PM
Please login to one that you don't use and remove payment method, it will get suspended
You will have 90 days to charge your mind
If you can't locate it, contact moderators directly at https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Make sure that your area discussing with them the right account
07-13-2020 07:12 PM - edited 07-13-2020 07:38 PM
@Iamthememe_ PM is a prepaid service, there are no refunds. Log into the self service account of the one that you don't want to use and remove the autopay credit card. The account will automatically close in 90 days. If you can't, then contact the moderators and explain your situation. Ask them to remove the credit card for you. There are 2 ways to contact the Moderator Team:
Once connected to Simon, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen. The mods answer will show up there. When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
Welcome to PM .
