03-13-2022
05:08 PM
03-13-2022
05:31 PM
computergeek541
i am looking to buy the Ulefone armour x9 pro and need to know if it will work on your network
this model is not listed in your compatibility link..but i saw an earlier post that said the x8 would work
these are the specs
much appreciated
you might then update the equipment compatibility list so as to help others that might follow
03-15-2022 08:22 AM
@softech - thanks for flagging. Yes. We're looking into the settings for the filter.
03-14-2022 12:16 PM
Also
In phone messages app settings
Turn off chat features
03-14-2022 11:01 AM
If u enjoy music sound quality thru bluetooth or headphone is sublime.
03-14-2022 10:50 AM
All apps work and updates for apps thru playstore is fulfilled automatic.
64 Gb internal storage is enough for me so I don't add a micro sd.
Protective film is already applied by factory.... extra tempered glass film in package. Remove factory applied film if u wish to apply tempered glass film.
A little tricky to insert Sim card as it sits "on top" of tray slot. Push the tray in slowly and make sure Sim stays in tray. Sim 1 is the deepest inset tray in phone. Rubber plugs covering Usb and headphone need a good fingernail pry to open.
The battery is good endurance but may not show 100% after charging.
Very good call reception and quality.
No need for a case and none are available.
Android 11 takes little space and is a treat.
micro usb charging
Order from Amazon with confidence especially from Ulefone Mobil-Global-NA.
They will answer your questions.
So far enjoying my upgrade.
03-14-2022 08:40 AM
sorry..last question...their online info is a little confusing as its different in a few sites
can i use SD card for expanded memory storage..it says up to 256gb?
did you need a protective film for the screen..it says its included?
did you get a case?
cheers
03-14-2022 08:34 AM
farmbot...have you had any issues with google play apps?
(VLC player, gmail, google home etc?)
03-13-2022 06:38 PM
Nothing better than experience shared by someone who has the phone and tried it . Thanks @farmbot.
03-13-2022 06:35 PM
Yes Amor x9Pro is excellent on Publicmobile network.
I have used 1 month.
Setting I use
under Mobile network
MMS messages On
send and receive when mobile data off
4G calling off
Advanced
wi-fi calling off
automatically select network On It will choose LTE for Data and fall back to 3G for voice
APN choose publicmobile
If you use a working active Sim all the settings will be available
Make sure that 4G calling is off you need 3G to talk.
Its an excellent phone. Cheers.
03-13-2022 06:26 PM
03-13-2022 06:23 PM
Good to know we have a workaround for the current issue....still needs to be fixed.
To pre-verify your account include your full name, address, email, phone # and 4 digit acct pin #
03-13-2022 06:21 PM - edited 03-13-2022 06:26 PM
@darlicious wrote:Lol...you were right with posting the compatibility bands and the spam filter deleting the posts. I remembered to take a screenshot immediately after my edit and the post disappeared seconds later. It looks like posts that include too many numbers will trigger the spam filter. So my initial post was okay but the edit was not.
@darlicious (and @J_PM ) I am not too sure if too many numbers triggered that. Like the following works (the filter just does not like to see PM's own frequency/bands.. LoL):
these are the bands for this phone, BOLD are those compatible with PM
3G bands HSDPA 850 / 900 / 1700(AWS) / 1900 / 2100
4G bands 1, 2, 3, 4, 5, 7, 8, 12, 17, 19, 20, 28
03-13-2022 05:33 PM
03-13-2022 05:26 PM - edited 03-13-2022 05:27 PM
This is the problem with the spam filter....as soon as I edited my post to include the compatibility bands the spam filter deleted my post.
