I am I. The usa I was able to use my phone for theist 10 days now I can't call out but everything el
02-06-2025 06:32 PM
02-12-2025 02:47 PM
Thanks everybody for replying I deleted the APN settings and re entered the APN and now all incoming and outgoing calls work
02-06-2025 06:35 PM
try manually selecting either T-Mobile or AT&T to see if that helps
02-06-2025 06:33 PM
so, call was working earlier?
do you have just Talk/Text addon or you have the Bundle or you have the Canada-US plan?
try reboot the phone, reset network settings
and also try connect manually to each of these networks: T-Mobile, AT&T and Verizon
