Huawei Y9
05-27-2020 01:48 PM - edited 01-05-2022 10:55 AM
06-05-2020 01:12 PM - edited 06-05-2020 01:21 PM
06-05-2020 01:12 PM
It is Y9 2019. I can try what you've recommended and let you know later.
thanks
06-05-2020 01:09 PM - edited 06-05-2020 01:10 PM
@amayassi wrote:I bought it from Kuwait, and I used it there and in Dubai, Jordan, Bahrain, Cairo and Lebanon, had no problem. Only in Canada with Public I can not use ir
@amayassi If it's the Y9 Prime 2019 it has very limited LTE connectivity B5 and B7 but it does support the 3G bands B2 and B5 so you should be able to use it on 3G.
06-05-2020 01:09 PM
MODEL JKM-LX1
06-05-2020 01:06 PM
model JKM-LX1
06-05-2020 01:04 PM
used it overseas. Virgin, Vodafone and local operators.
06-05-2020 01:02 PM
06-05-2020 01:01 PM
06-05-2020 12:58 PM
it is unlocked
05-27-2020 06:34 PM
@amayassi There can be mulitple versions of a model, some compatible and some not. Which carrier was this phone used at before?
05-27-2020 02:39 PM
@amayassi hi try resetting your network settings on the y9.
- open settings>advanced settings
- tap backup & reset
- tap network settings reset
- and tap network settings reset to confirm
- restart your phone and test
05-27-2020 02:00 PM - edited 05-27-2020 02:02 PM
Is it the global version ?
05-27-2020 01:57 PM
05-27-2020 01:53 PM - edited 05-27-2020 01:54 PM
@amayassi hi is the Y9 unlocked? If not go to your previous provider ask for unlock code
