07-13-2019 07:27 PM - edited 01-05-2022 05:52 AM
Hi,
My phone mode is HUAWEI P30,I am not sure whether or not available for public mobile SIM card.
Thank you!
Cheers,
Adele
07-21-2019 07:39 AM
I had already solved this problem. HUAWEI P30 is available working now. Thank you guys!
07-14-2019 01:53 AM
@AdeleC wrote:Hi,
Thank you!
Cheers,
Adele
Your phone will work with PM; however, it needs to be unlocked.
To verify your phone is unlocked; you may want to borrow someone elses SIM card (with a different service provider than your current) to test.
If you do find your phone it locked; you've got a few options to unlock.
If you're still active with your service provider; call them. They are required by regulation to unlock your phone for free. If you're no longer with them; you can still try, but they maybe be unwilling do so if your not a customer anymore & there's no way to establish you're the owner of that phone.
You can try an instore/online unlocking service (I've previously used various ebay resellers to unlock my phones ~$5 or less).
Good Luck!
07-13-2019 08:59 PM
@AdeleC wrote:Hi,
Thank you!
Cheers,
Adele
P30 is an amazing Piece of hardware. If it's unlocked it will work regardless where you bought it as models of the P30 are Public Mobile compatible.
07-13-2019 08:08 PM
You can always try https://willmyphonework.net/
07-13-2019 07:31 PM
Your phone will work with Public mobile. Here are the specs:
https://www.gsmarena.com/huawei_p30-9530.php
3G bands | HSDPA 800 / 850 / 900 / 1700(AWS) / 1900 / 2100 |
4G bands | LTE band 1(2100), 2(1900), 3(1800), 4(1700/2100), 5(850), 6(900), 7(2600), 8(900), 9(1800), 12(700), 17(700), 18(800), 19(800), 20(800), 26(850), 28(700), 32(1500), 34(2000), 38(2600), 39(1900), 40(2300) |
Public Mobile uses the following frequency bands:
07-13-2019 07:29 PM
@AdeleCIf it is purchased in North America and unlocked, there is a high probability that it would work. The best way is just to test it yourself with any SIM card from the Telus group.
