11-13-2019 07:35 PM - edited 01-05-2022 07:58 AM
01-20-2025 08:46 AM
11-10-2021 07:48 PM
What was the exact message on your phone, ? there are 3 different kinds and different actions for different one.
there is one for just the lock for the SIM card, which PM can provide you
there is one for carrier lock, which you have to find it from where the phone you got from
there is a master lock that usually applied for Samsung phones and Samsung can provid you.
So, what was the exact error message?
11-10-2021 07:44 PM
11-10-2021 07:42 PM
11-13-2019 08:34 PM
@liezl_gamrot Are you certain it's a PUK that you need? Sometimes when someone requests a puk code, it is actually not what is needed.
"SIM network PIN blocked. Enter SIM network PUK." is asking for the phone’s (often Samsung) “master code" after entering the wrong code too many times. Samsung and/or your previous carrier can give you this.
"SIM network unlock PIN" is asking for your previous carrier's unlock code - just contact them with your IMEI and they'll give it to you. If you enter this incorrectly too many times, you'll get the error message above.
“PIN unlock key (PUK)” is a SIM-specific code used to prevent unauthorised use of a SIM card.
The PIN (Personal Identification Number) enables secure access to the SIM card and network. It is provided with your SIM card.
If the PIN code is entered incorrectly 3 times, the phone is locked (except for emergency calls) and requires a PUK (Personal Unlock Key) to reactivate it.
Once the PUK is recovered and validated, you will be asked to choose a new PIN.
Only Public Mobile's moderators can give you this type of code, which the device manufacturer cannot.
Caution! If the PUK is entered incorrectly ten times in a row, the SIM card becomes unusable.
11-13-2019 07:37 PM - edited 11-13-2019 07:39 PM
You'll need to click ? in lower right side of screen to start process of contacting a moderator. Type "PUK code" and follow directions.
