07-24-2017 04:28 PM - edited 01-04-2022 02:24 PM
I have been on PM since 2016 but wondering how I can tell what speed rate is my data plan detail. It only said 12 GB. It does not say if it is 3G or 4G LTE. Can anybody tell me how to find out ?
Thanks.
12-18-2017 11:44 AM
@Rockdaddy22 wrote:That’s totally false
@Rockdaddy22 that's not necessarily true. I'm not sure if it's still the case, but at least originally, adding the throttling to new 3G users was a manual process, which is why it could take up to 72 hours to be applied. It's quite conceivable that a few may have slipped through the cracks, or that the process of applying the throttling may have been done incorrectly, incomplete, or just fallen prey to a glitch.
12-18-2017 04:41 AM
12-18-2017 02:56 AM
@Rockdaddy22 wrote:
@xCameron94x
Good point about joining in 2016. Your other point though needs correcting, this new 3G plan is actually throttled LTE, not 3G, so the phone will still show LTE unfortunately. Speedtest would tell you of course 🙂
I paid for a 3g plan but can still use un throttled lte! At 30-100 mbs per second, but i do prefer to use 3g (set in settings) because i tend to have better reception & phone calls only work on 3g anyways, so not really sure why everyones saying its "lte lite" when i have the same speeds as my old telus plan
09-01-2017 02:33 PM
09-01-2017 01:29 PM
Thanks! @SD08
09-01-2017 01:26 PM
Don't forget to thank @SD08, @mikga! 🙂
09-01-2017 01:24 PM
Thanks! @srlawren
09-01-2017 01:19 PM
@mikga please see @SD08's reply for the information you seek 🙂
08-31-2017 05:56 PM
@mikga wrote:@srlawren Hi, just learnt that PM has 3G & LTE. My phone shows 4GLTE means that mine is LTE, right as I joined in 2016. Sometimes I saw 3g occasionally. Does it mean that maybe in some spots connection is 3g only.
Thanks!
You have a 4G/LTE plan. All plans activated before July 13, 2017, the date of introduction of PM's 3G plans, are by default LTE.
Also, you can tell by your plan details under Plan & Add-ons. Any 3G plan is marked like this:
08-31-2017 04:41 PM
Thanks!
07-26-2017 11:53 AM
Please keep us posted, @cornpops
07-25-2017 11:57 PM
@srlawren The plan posted on my account definitley does not have "at 3G speeds" posted. My phone's preffered network has always been on LTE preferred.
This is quite odd, I will contact a moderator.
07-25-2017 07:54 PM
@cornpops although extremely unlikely, it's conceivable that your account may have accidentally been included in "throttling" that gets applied to people selecting one of the newer "3G" data plan options. Could you firstly sign into your self-serve account and check your Plan Details to make sure it does not include the phrase "at 3G Speeds" after your plan's data amount?
Also, on your phone, make sure you haven't accidentally set your network preference to exclude 4G/LTE. And maybe also try a reboot, that can cure a lot of "unusual" or suddenly changed behaviour.
If all that fails, then definitely send a private message to @CS_Agent to investigate the issue for you.
07-25-2017 06:53 PM
I signed up before the 3G plans got introduced, but I seem to be constantly getting H speeds on my phone now. I was getting 100% LTE speeds before the switch over. Odd.
07-25-2017 05:22 PM
@srlawren wrote:Here's how you can tell. Plans with 3G data show up this way in Plan Details in your self-serve account:
This image was taken from my "3G" test account.
Plans with full speed/4G data do not include that "at 3G Speed" part. Here's my primary line (on 2016 Fall Promo plan) for comparison:
Yes that is what I have in plan detail showing only "12GB Data" so I assume that represented 4G LTE.
Thanks.
07-25-2017 05:18 PM
Thanks for clarifying this. (Adding this to my e-mail archive. )
07-25-2017 04:35 PM
07-25-2017 03:56 PM
07-25-2017 09:23 AM
07-24-2017 05:40 PM
07-24-2017 05:16 PM
Thanks to all for confirming that there is no way to tell in the plan detail that what rate plan I am on except from the phone connection.
07-24-2017 05:06 PM - edited 07-24-2017 05:06 PM
@norstar, if this is something that you are worried about if it will change in the future you can always monitor it your self using www.speedtest.net Great app for testing network speed
07-24-2017 05:04 PM
@mimmo wrote:the 3g (lte Slow) is a new feature. I am sure if someone buys a new plan there will be a distinction an identifier stating LTE regural or LTE Slow.
Sorry; there is no plan to change the network identifier. The only indicator will be the plan designation in one's account.
07-24-2017 04:35 PM
07-24-2017 04:33 PM
Thanks for the quick resply. Yes it shows on the phone but I was wondering why it does not say so on the plan detail.
07-24-2017 04:30 PM
If you joined in 2016, you will be using LTE. Also your phone will show in the status bar (LTE,3G, ect, ect)
