07-02-2020 03:24 PM - edited 01-05-2022 11:56 AM
01-12-2024 03:40 PM
I had an issue with my Galaxy S8 (Android 9 Pie), where holding down the '1' key brought me into my settings to an option to add my voicemail number, but when actually entering in any number it would always return with a "Voicemail number can't be changed" error message. Calling my own 10-digit phone number did work however, and I set things up from there. Thanks for your help!
07-02-2020 03:31 PM
Welcome to Public Mobile! Once you activate your phone number can begin receiving voicemails. Voicemail can be accessed by long-pressing on the 1 key on your phone. You will then be taken through a menu to set up your greeting and PIN.
07-02-2020 03:31 PM
Here is more info.
https://www.publicmobile.ca/en/bc/get-help/articles/set-up-voicemail
07-02-2020 03:31 PM
@gblackma lol
07-02-2020 03:29 PM - edited 07-02-2020 03:29 PM
👍😎3 measly seconds. @Jb456 .
07-02-2020 03:28 PM
@gblackma to slow 🤣
07-02-2020 03:27 PM
Welcome to PM @PingRoll, here's an article on setting up your voicemail. https://www.publicmobile.ca/en/on/get-help/articles/set-up-voicemail . Stay safe.
07-02-2020 03:27 PM
Setting up Voicemail
After you’ve activated, your voicemail is automatically ready to accept messages as soon as you add it to your account. It will play a default greeting until you set it up. Setting it up isn’t complicated:
