How to set up APN settings for SAMSUNG S21
HopefulChicken
2 hours later here is what I figured out…
Open Settings on your phone (swipe down twice and hit the gear icon for Settings)
Follow this path:
Settings - More… (Airplane mode, Tethering, VPN) – Cellular Networks – Access Point Names (APN)
Once in APN hit the “kebab setting menu” (three vertical dots on the top right) then hit -Reset to default
My phone had a Koodo and TELUS APN settings come up, ignore them and hit the “+” (top right with a circle around it) and then manually input the following APN settings (please make sure it is all exact even upper- and lower-case letters):
APN: sp.mb.com
APN type (select each one): default, mms, supl, wap, net
Proxy: not set
Port: not set
Username: not set
Password: not set
Server: not set
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN protocol: IPv4/IPv6
APN roaming protocol: IPv4/IPv6
Bearer: Unspecified
MVNO type: GID
MVNO: 4d4f
Once all info is correctly manually entered hit the “kebab setting menu” (three vertical dots on the top right) hit SAVE
Then Press and hold the power button on the outside of your phone then select – Power off and let your phone power down (I tried using Restart and it did not work)
After your phone is powered down turn it back on and data and picture texting should work.
I hope this is helpful to someone else.
@HopefulChicken
you can try to reset network settings on an Android device
  1. Open the Settings app on your Android.
  2. Scroll to and tap either "General management" or "System," depending on what device you have.
  3. Tap either "Reset" or "Reset options."
  4. Tap the words "Reset network settings."
   or visit  Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
and do again Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
@HopefulChicken
Nice post. Did your data not work previous to you editing the APN? Is your phone CPU? Samsung phones normally populate the appropriate APN after inserting the sim card. Often the APN will list telus or koodo as the provider but the APN will still work for public mobile.
Usually the APN will come down automatically.  Maybe a reboot once or twice with couple minutes wait is all it needs
