12-07-2019 12:41 PM - edited 01-05-2022 08:24 AM
How to put 2 account in same my online account
I have 2 account but I want to have them under one e mail
What should I do?
12-07-2019 05:29 PM - edited 12-07-2019 05:30 PM
@hairbag1 wrote:
@pomlady wrote:Hi, not sure I get this? Right now I only have one cell phone with Public and I am not using my gmail account for that.
Once my other cell phone is off contract in the Spring, I want to bring it over to Public too.
So what I am understanding is, when I do that, I can't use the same email address?
I do have a gmail account that I could use if need be.
If I have two cell phones with Public, can I go into my account and see them both? or do I have to have two separate accounts and pay them individually?
Thanks for any infor. Will be easy to do when the time comes:-).
You need a separate/different email address for each phone account.
Thanks to everyone. Think I will just do that then, two accounts; one to my regular email account and one to the gmail account. Seems like that would be easier in the long run. Appreciate all the replies:-).
12-07-2019 05:13 PM
You can try going into the "my account" section, and the click on "my profile" and then "change username" as your log in "username" for your account is technically your email (unlike here where you actually have a username, that's linked to your email) hopefully that works!
12-07-2019 02:54 PM
@ChuckYeah wrote:@Raf414 If you have a Gmail account, they support aliases. Your.name+line1@ and Your.name+line2 will still have to be seperate accounts, but all emails related to each will go to Your.name@. You can set up a couple of rules to separate the two accounts as well.
Gmail also doesn't recognize the '.' character in an email before the @. So to use the above example Your.name@ and yourname@ would go to the same inbox.
12-07-2019 01:39 PM - edited 04-05-2020 12:29 AM
Stay Safe!
12-07-2019 01:39 PM
12-07-2019 01:38 PM - edited 12-07-2019 01:38 PM
@pomladyYou have to use 2 email addresses and keep them seperate.. (and pick one for your community account if you want to earn rewards from participating in this forum.that is the easiest method.
Alternatively if you use GMail you can use their Alias function basically fooling Public Mobile to think that your email eg pomlady+Email1@gmail.com is different than pomlady+Email2@gmail.com. if you try to email both of them them would actually go to pomlady@gmail.com
12-07-2019 01:34 PM
12-07-2019 12:56 PM
I would definitely like they
12-07-2019 12:46 PM
12-07-2019 12:43 PM - edited 04-05-2020 12:29 AM
Stay Safe!
