How to get into my public account
Anthony13
How do I get into my public account after forgetting email that I used to set it up
2 REPLIES 2
@Anthony13 you tried to access via   https://selfserve.publicmobile.ca ?
If it is an password issue,  try to use the Reset Password link there on the login page (or direct link: https://myaccount.publicmobile.ca/en/forgot-password) enter any possible email addresses you could have used and see if it works
if not, PM support will be your friend then, please open ticket with them
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
Public Mobile sent an e-mail message aftter activation. Please look for that.  The e-mail address that the e-mail message was sent to would be your Self Serve login username.
