How to get customer support from Public mobile when I can' Find the answer on community chat
Pauly1
Hi, I’m having issues transferring my mobile number from Rogers to Public mobile. Is there a way to speak with someone at Public mobile to fix the issue. How can I transfer a phone number without having my old SIM card from Rogers? Thanks
dust2dust
Is your Rogers service still active? That would be the first requirement. Then, you might be able to call them to give a verbal confirmation. Or you might need to buy a Rogers sim and apply to that account and maybe even buy a month of service.
hairbag1
@Pauly1
part of the port process requires that you still have the old sim in the phone until it closes. Take a random number for now, then start asking to have the old number found and used for your PM account.
added..
https://www.publicmobile.ca/en/bc/get-help/articles/transfer-your-number
.https://www.publicmobile.ca/en/bc/get-help/articles/number-transfer-port-troubleshooting
Phil_Adelphus
Yes, I will private message you the number (which is for porting issues only) so check your messages in a minute or two
